Disables LDP for the switch.
Disabled.
When LDP is disabled, all advertised LDP labels are withdrawn and LDP peer sessions are terminated. Note that this includes any LDP peer sessions established for L2 VPNs. By default, LDP is globally disabled. While LDP is transitioning to the enabled state, only the MPLS show commands are accepted.
The following command globally disables LDP on the switch:
disable mpls protocol ldp
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
